Drives: 2008 Yaris Join Date: Oct 2014
Check engine light
we have a 2008 Yaris sedan. We just hit 55800 miles. And the check engine light has come on. Since it came on exactly when it hit 55800 I'm wondering if anyone knows if this is way to try and get us into the dealership for some unneeded tune up. The car itself seemed to be running fine. In need of an oil change but nothing else.
![]() Drives: Yaris Join Date: Oct 2014
Loose gas cap? Did you fill up recently?
#3 | |
As there are hundreds of codes which could be thrown, you really need to get it read. Could be evap (gas cap), O2 sensors, random misfire, just to name a few.
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
see it all the time
I see it all the time where people at the pump will top off their gas tank which causes the evap system to fail.
Let us know when you find out what it is. |
#5 | |
#6 | |
By topping off as in filling up until you see gas at the cap. I never top off that much. First click and maybe add 1 or 2 more litres. |
#8 | |
). When CTScott figured that the maximum capacity of the tank is 12.8 gallons, I knew this was correct because: 1. It's CTScott, and 2. Because of my 'running out of gas while pulling into a station' experience.
![]() ![]() Drives: Want a yaris Join Date: May 2012
Run by autozone. They will give you a code readout for free. Post the code on here and we can help you out
Mr J.
Is it the CEL or is it the Maint Req light? Maint req is not a CEL and does not throw codes according to the dealership. That is for their recommended oil changes, filter changes etc. If it is in fact a CEL then you need to have someone run a scanner on it and see what code(S) are being thrown. Maint req lights are easy to reset and take off, the CEL you ofc would have to fix w/e it is throwing the code then it'll go away.
| help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 06:17 PM |
| Cold air intake....check engine light on...??? | JohnnyMalice | Performance Modifications | 4 | 04-29-2012 09:46 PM |
| Differntial diagnosis for the check engine light yaris sedan | dante2086 | DIY / Maintenance / Service | 1 | 12-18-2010 09:04 AM |
| Got engine check light :( | jmew0ng | DIY / Maintenance / Service | 15 | 07-01-2009 10:09 PM |
