Old 10-09-2014, 11:54 AM   #1
alanwagen
see it all the time
I see it all the time where people at the pump will top off their gas tank which causes the evap system to fail.
Let us know when you find out what it is.
Old 10-11-2014, 09:20 PM   #2
nookandcrannycar
I guess I'm just lucky. I've been topping off ever since I got my learner's permit, and I've never had to replace any fuel related parts on any vehicle .
Old 10-11-2014, 10:57 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
By topping off as in filling up until you see gas at the cap. I never top off that much. First click and maybe add 1 or 2 more litres.
Old 10-12-2014, 08:47 AM   #4
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
After the first click, I just round it off to the next dollar
nobodywise is offline   Reply With Quote
Old 10-13-2014, 12:10 AM   #5
nookandcrannycar
There was a past thread where one of the main questions was (I'm paraphrasing) - 'Is the click an unfailingly reliable 'set point' for figuring MPG (will it ALWAYS happen in the same place), or can some sort of malfunction cause a difference. CTScott weighed in with at least one scenario/malfunction that could cause a difference, and (IIRC) others did as well. I've always applied 'my style' (filling until I can just see gas in the neck), so that thread confirmed that my quest for accuracy and consistency (however picky and 'OCDish') has some concrete basis. I suppose if I ever had a fuel related part fail on a car I might reevaluate 'my style'...but I can't think of anything else off the top of my head that would compel me to do so.
Old 10-13-2014, 03:47 AM   #6
alanwagen
why risk it
It may be just a matter of time before you foul your canister. But actually there are more reasons to NOT top off your tank. You can Google them but this one here seems very convincing.
http://www.epa.gov/donttopoff/
Old 10-12-2014, 11:45 PM   #7
nookandcrannycar
Filling until I can see gas in the neck. I know that = 12.777 U.S. gallons because I once ran out of gas as I was pulling into a gas station (). When CTScott figured that the maximum capacity of the tank is 12.8 gallons, I knew this was correct because: 1. It's CTScott, and 2. Because of my 'running out of gas while pulling into a station' experience.
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
Cold air intake....check engine light on...??? JohnnyMalice Performance Modifications 4 04-29-2012 09:46 PM
Differntial diagnosis for the check engine light yaris sedan dante2086 DIY / Maintenance / Service 1 12-18-2010 09:04 AM
Got engine check light :( jmew0ng DIY / Maintenance / Service 15 07-01-2009 10:09 PM
