![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
Glove box door pop open?
Hi all. My glove box door on 2009 Yaris sedan is always popping open. Is there an easy fix for this? Is this a common problem? Every time I rest my arm on there, it will pop open when I take my arm off for a second. I was hoping someone here had already come up with a DIY fix.
#2 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Its probably just me, but to the OP, did you mean arm rest/center console compartment cover?
This isnt a problem ive encountered, but if anything it should be that the plastic to lock it in place is loose. |
I think he meant center console, It would be hard for a driver to "rest" his hand on the glove box.
Both of you are obviously correct. I read 'glove box door' and thought 'I can vent just a little bit about a small peeve' (the glove box never fitting the same after putting a cabin air filter in the empty (from the factory) cabin air filter slot), and didn't pay close enough attention to the rest of the post.
Yeah sorry about that. I didn't read it after I wrote it. It's the center console door.
DIY fix? i say move expand the screw holes of the metal hinge (that attaches to the cover itself--the part you put your arm on) so that you can slide the cover a little farther back.
Excellent. One of those "duh" moments. Can't believe I didn't think of that.
| Dual 8’’ Cargo Floor Sub Box Build | Ataristyle | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 03-23-2016 01:27 AM |
| Advantage Drivers Side Glove Box! | bronsin | General Yaris / Vitz Discussion | 15 | 02-18-2014 12:42 PM |
| Sub Box Desgin | talnlnky | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 08-23-2009 01:45 AM |
| Rubber plugs in glove box | cfiimei | DIY / Maintenance / Service | 5 | 01-06-2009 04:48 AM |
| FS: Glove Box Damper (GTA) | Teruyume | Items for Sale by private party | 1 | 07-02-2007 01:58 AM |
