Old 10-13-2014, 09:24 AM   #1
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
I just installed a Curt 11050 on my 09 (which your 2011 would use as well). Once you install the hitch, you could use any bike rack that fits a 1-1/4" receiver. Here's a link to what it looks like. Installation took less than 30 minutes.
http://www.yarisworld.com/forums/showthread.php?t=52489
If by dirt bike you mean a motorcycle, rather than bicycle, then you would not want to use a rack, but rather a small motorcycle trailer, as it would be too heavy for the tongue weight rating.
Do you know if that Curt 11050 will fit an '11 equipped with TRD cat-back and TRD rear sway bar?
I'm the Prez at my house...in fact I cruise around in YarForce One!
When I'm not driving my Yaris, I'm doing this:
http://gogogordy1.wix.com/scooter-aficionado
Gogogordy is offline   Reply With Quote
Old 10-13-2014, 09:34 AM   #2
I believe it will with no problem. Installed, the only thing that hangs below the bottom edge of the bumper is the receiver (in the center). By the exhaust it is completely tucked up there.
Old 10-13-2014, 07:28 PM   #3
Gogogordy
No interference from the TRD?
Thanks for the reply. The TRD seems a bit larger than the OEM exhaust....ample clearance with the Curt. Does anyone have any pix of the Curt towbar in relation to either the OEM or TRD exhaust?
Old 10-13-2014, 09:21 PM   #4
Here's a pic of mine with the OEM exhaust. As you can see, the only place where the curt extends below the bumper plastics is at the rear tie down:
Catastrophic Yakima Roof Rack Failure Kaykogi General Yaris / Vitz Discussion 8 08-14-2012 03:59 PM
Roof rack question / Thule fit kit or Yakima drilled option dasnake DIY / Maintenance / Service 20 03-22-2012 11:43 PM
Another roof rack option for Yaris! Cosworth General Yaris / Vitz Discussion 6 08-07-2011 10:29 PM
OK BIKE RACK ON YARIS WUT YOU GUYS THINK??? jdm-yaris Cosmetic Modifications (Exterior/Interior) 9 08-22-2010 01:43 AM
Removing Power Steering/Replacing PS Rack with Manual Rack eii DIY / Maintenance / Service 13 07-02-2010 08:05 PM
