Old 04-13-2007, 09:53 AM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Tire Nazi here to save the day!
if you want to run an 8 in wide you want +38 offset that will set your wheel dead flush with your fender and will cause no rubbing on the inside wheel well. I would suggest a 225/50R15 tire, as it would keep the overall diameter if the tire very close to stock.
do not run the +45 as Peterredyaris said or you will be rubbing all the time, I can see why he had such bad rubbing problems running that offset on that width
You should be fine with 8 in wide wheels, because I am running a 8.9 inch wide tire (225/50R15) on a wheel with a +38 offset and they set as described above, it will work
You recommend +38 for everything. Stop making reccomendations based on your setup. You obvoiusly have 0 experience with lowered Yarii and have NO IDEA how offset dynamically changes with wheel width. +38 on an 8 inch wheel will rub the outer fender horribly if he lowers the car more than an inch or so. It will stick out 15mm more than a 7 inch wheel with a 40mm offset which is nearly flush.
Here is a simple offset calculator. See for yourself.
http://1010tires.com/WheelOffsetCalculator.asp
You previously said that a 7 inch wheel with +38 is perfectly flush. which it is, but it will rub on the outer front if you are lowered. So by your account now both +38 on a 7 inch wide wheel and +38 on an 8 inch wide wheel will be perfectly flush? NO. the 8 inch wheel will STICK OUT 13 MM beyond the fender of the 7 inch wheel.
Addtionally there will be 13 mm LESS clearance on the inside. To put that into perspective, that would be the equivelent of running a + 51 7 inch wheel which MAY rub on the inside. I dont know that for sure.
So if he lowered the car he would probably rub on both the inside AND outside of the fender based on your recommendation.
To the original poster:
If you are not lowered at all and dont plan to you will probably need an offset in the mid to low 30s to run 8s. If you plan to lower the car Black yaris has no idea what he is talking about regarding this topic, and you may need really low profile tires to keep from rubbing the outer fenders, and the wheels will stick out.
You could probably get 8s in the back and get it looking pretty good and nearly flush or flush, but to get that look in the front you will probably have to go with a narrower front with a different offset.
Old 04-13-2007, 11:18 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
you need to read a bit further in to what I say young one.... I am sure I know a hell of a lot more than you when it comes you wheel, tires, and custom suspensions.
contraband831 I ask you this, do you want to lower your Yaris? Do you mind if you have some rubbing on full lock turns? What is the reason for running the 8 in wheel looks? just answer a few of these questions, ignore largeorangefont, and click on the link in my signature and PM me if you have anymore questions
Old 04-13-2007, 11:40 AM   #3
largeorangefont
Break'em off some.
No, you actually don't. Your blanket recommendations and misinformation in this and other threads reflect that.
These should have been questions you asked before you spewed misinformation. Your recommendation of +38 will be flush is flat wrong. If the original poster wants to listen to your opinion or the actual facts I provided, that is his choice.
Your tire right sizing guide thread is great, but has no specific offset information making it an incomplete answer to the question at hand.
Old 04-13-2007, 11:56 AM   #4
Black Yaris
der Zeck
if you would like I will update my wheel/tire thread with every offset/width option as well as variable which lowering springs, but that would be a lot of information for most to sift though... I was asked to make something for MOST, AVERAGE drivers... and that is what I did... if anyone wants anything out of the norm, as does this person, all they need to do is ask.
and I checked out that 1010 tires offset calculator, WOW could that thing be more off, I just checked it on a couple of my old rides that I knew like the back of my hand, it was coming up with some off sets like +100 and stuff like that who knows? but I do not think that is correct source of information for offset, but I do like there tire calculator
Largeoragefont you just need to calm the fuck down, and show a little , as I will from this pont on, Fair?
Old 04-13-2007, 12:45 PM   #5
largeorangefont
Break'em off some.
Fair enough. On a serious note, What was wrong with the calculator? I found it to be very accurate for guaging how much space you gain or lose in relation to offset and wheel width. What were you putting in?
Compare a 7 inch wide +40 offset to a 7.5 +40 offset for example. That is correct.
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
Do bigger wheels and tires improve performance Driver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 10-14-2006 06:01 PM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 04:22 AM
