Old 10-14-2014, 09:08 PM   #1
Originally Posted by Lets Go Giants View Post
I have a 2008 yaris and it's not turning over. It sounds like it wants to start but won't turn. The car broke down on the freeway and my thought was it was the fuel pump which i replaced. The car still wont start, I am looking for the location of the fuel pump relay but can not find it anywhere. Any help on this would be greatly appreciated. Thanks
The fuel pump relay is integrated into the body ECU (which is the under dash fuse box assembly). If you do some searching on here you'll find a thread where I give instructions on how to test its output and bypass it if it is bad.
If it is not turning over, then the fuel pump is not the issue. If it cranks by doesn't start then it could be.
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Extended car warranty from Toyota pip DIY / Maintenance / Service 3 05-30-2011 09:12 PM
Noise when first starting car and turning steering wheel kaileeg DIY / Maintenance / Service 0 11-15-2010 04:51 PM
Slow cranking on an 02 1.0 vvti Yaris Duberry UK 0 11-01-2010 09:20 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
