Old 04-27-2010, 01:18 AM   #1
detroiter
detroiter's Avatar
I would like to know what would be a good size tire to run on stock rims, with Tein Stech springs and TK blue shocks? I'm looking at 205-55-15 or 195-55-15. I prefer the 205 but don't know if I'll have rubbing issues. Please let me know
Old 07-27-2010, 06:41 PM   #2
yarisboi
Drives: Yaris 1999 3dr
could i fit 15 x 6.5J alloys to my yaris without any clearance issues/rubbing arches with cornering? i've got a 99' 1.0 lol
yarisboi is offline   Reply With Quote
Old 07-31-2010, 08:42 PM   #3
vic2099
Drives: 01.Yaris1-1.3vvti.5D
Hi Everyone, Im new here with my new bought Yaris I 2001 1.3vvti.
It has 175/65/14 steel wheels with ET probably 45 or 46.
I'm wondering if 7Jx15 ET38 with 195/50/15 tire wouldn't be just perfect?
In this size 195/50/15 comes so many tires - the choice would be huge. Also - 195/50/14 is cheaper sometimes than 185/60/14 or 175/65/14 !!
So I think the best of the best choices for now to me Yaris will be this setup:
7Jx15 ET38 4x100 54.1mm with Uniroyal Rainsport or Rainexpert tires 195/50/15. The cheapest chips aye?
The Australian.
vic2099 is offline   Reply With Quote
Old 08-05-2010, 08:23 AM   #4
slapper
Drives: Yaris TS 1.8
Hey guys.
Need some assistance, i drive the new TS. It comes out with “205 45 R17” can i change it to “205 40 R17”? Will it affect the performance of my car? Will it damage the gearbox?
slapper is offline   Reply With Quote
Old 08-05-2010, 08:43 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by slapper View Post
Hey guys.
Yes, you can run 205/40's without any problems whatsoever... but WHY would you want to do that???
Old 08-05-2010, 10:21 AM   #6
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Smile
Yes you could.
Yes will affect performance, acceleration and breaking will be quicker (due to a smaller diameter) it's going to feel peppier, and will turn corners faster
No It won't damage gearbox
Your speedo will read a 3 or 4 MPH faster than actual (at highway speeds) aprox.
The gap between tire and fender will be bigger
Your ride will be harder (less rubber) you may feel bumps more than before.
I'm not an expert on the topic but I hope it helps, I'm sure other YarisWold members would have something to say, specially the ones that have done this exercise!
What is your goal changing tires size?
Old 08-07-2010, 09:38 PM   #7
limochong
limochong's Avatar
Drives: 2007 yaris sedan
i have 2007 yaris sedan model. original size for the tyre is 185/60/15 or 15x 5.5...
okay now i want to get rim which is 15x6 is it okay to put it on?? guys your comments are greatly appreciated...
limochong is offline   Reply With Quote
Old 08-07-2010, 09:50 PM   #8
kimona
kimona's Avatar
No problem going with wider wheels... 15x6, 15x6.5, 15x7.
Old 08-07-2010, 10:49 PM   #9
Billiam
Drives: '10 White Yaris 4D LB
Here's some 15x6, +39mm offset wheels with 205/55 tire. Fits just fine.
If you want to enjoy your car, stay off of the internet.
Old 08-07-2010, 11:48 PM   #10
limochong
limochong's Avatar
just curious question, what's the difference between 15 x 5.5 and 15 x 6??
is it okay with 185/60/15 size tires on15 x 6 rim?
Old 08-08-2010, 12:00 AM   #11
kimona
kimona's Avatar
The difference is 1/2". 185mm tyre can fit on wheel width 4.5-7.0"
Old 08-08-2010, 08:26 AM   #12
limochong
limochong's Avatar
thanks buddy~
Old 08-14-2010, 02:27 PM   #13
vic2099
195/50/15 are much cheaper than 195/55/15.
I have 2001 model and next week I'm fitting 15x7 ET38 rims with 195/50/15 tires. Not lowered.
Old 08-18-2010, 09:28 AM   #14
vic2099
Here we go, here we go, HERE WE GOOOOOOOO !!!!!!!!!! YEEEEEEEEEEEEEEEEE
Perfect fit !!!!!!!!!!
Stock 5Jx14 (or 5.5Jx14, to dirty to see :) ) 175/65/14 replaced !!!!!!!!!!!!
195/50/15 with Toyo Proxes 4 tires , ET38, centric rings 60.1>54.1, 7Jx15, new nuts, VOILA !!!!!!
Im gonna get drunk tonight with VB beer :D
TADAAAAAAAAAAAAAA !!!!!!!!!
Michael
Old 09-02-2010, 07:00 PM   #15
shastatodd
Drives: 2009 RED Yaris
Will a larger diameter tire which will lower engine revs give me better fuel economy? Most of my driving in on the freeway. The stock tire is 175/65/R14.
I can get the Michelin Hydroedge in:
185/65/R14
185/70/R14 or
195/70/R14 (assuming this tire will fit the clearances)
While bigger tires are heavier and less efficient, they will also raise the effective gearing,lowering the engine revs which should benefit MPG's right?
Thanks in advance for the help with this.
Todd
shastatodd is offline   Reply With Quote
Old 09-03-2010, 06:24 AM   #16
kimona
kimona's Avatar
185/65/R14
185/70/R14 or
Todd
185/70/14 would be an excellent fitment at 24.3" diameter... equivalent to OEM 205/45/17.
Old 09-03-2010, 12:40 AM   #17
sleey0
Drives: 2008 Yaris LB
Allright folks.
Getting some +45 ET RP03's - 17x7.
Are 215/45/17 the rec tires for this? I am lowered about 1.5 inches.
I see the diameter is more. So maybe 215/40 or 205/40?
Confused?!?!
Thanks!
sleey0 is offline   Reply With Quote
Old 09-03-2010, 06:26 AM   #18
kimona
kimona's Avatar
Originally Posted by sleey0 View Post
Allright folks.
Confused?!?!
Thanks!
I'd install OEM tyre size 205/45/17 with that wheel and your drop.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
