Not typical for a wp to soak the tire. Its on the right hand side of the engine and is driven by the outside flat part of the belt. The pulley for it is flat also that's how you can tell.
Its not on the inside of the engine whatever that means. I suspect a hose. Goodluck and tell us what happens!
| water pump change 2sz-fe | finnpoulsen | DIY / Maintenance / Service | 5 | 03-25-2020 10:20 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 12:33 PM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| HELP: changing water pump | dlplunkett44 | DIY / Maintenance / Service | 4 | 02-06-2011 09:26 AM |
