Old 10-20-2014, 06:39 AM   #1
Originally Posted by Adriaan View Post
Battery and alternator were checked, all good. But for the immobilizer if she gets one from a scrap yard, do the keys have to be reprogrammed? Also are the immobilizer year specific so and 08 for and 08 etc.?
Again - If it starts and dies it is not the immobilizer. The immobilizer is part of the ECM, so if she did decide to replace that she would need one of the original master keys from the car that the used ECM came from in order to program it with the keys for her car.
If you can confirm that it actually does start and die (as opposed to crank and not start), then I would look for vacuum leaks, bad MAF sensor, issue with plugs or coil packs, or a fuel system problem (bad fuel pump or plugged fuel filter).
Yaris, very mysterious, electrical problem (VIDEO) csrblanco DIY / Maintenance / Service 6 07-09-2014 04:05 PM
Yaris Gearbox gear change problem? slnko2003 General Yaris / Vitz Discussion 1 08-20-2012 01:26 PM
Yaris Reverse Problem - Automatic fowmd887 General Yaris / Vitz Discussion 3 06-28-2012 06:11 AM
