Old 10-20-2014, 06:42 AM   #1
Originally Posted by CoryM View Post
Not sure how the Yaris key reminder switch is wired, and oddly enough the online manuals are missing that page, but I think you will find the switch is grounded and it thinks there is always a key in the ign. May be as simple as spraying a little lube on the key to free up a stuck switch. Again, no idea how the Yaris switch looks so can't advise further, other than to try unplugging the switch if possible.
Cheers.
That's actually a good idea if he doesn't find an aftermarket wiring issue. The key reminder switch is a small plastic pin switch that is mounted just below the ignition switch on the steering column. It has a two pin connector with a yellow and white/black wire.
Driver Side Mirror - Can This Be Replaced Easily? (Image Attached) Yarismo123 DIY / Maintenance / Service 3 10-06-2012 10:04 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
Front Driver Side Wheel Chirping Hard_Yaris DIY / Maintenance / Service 5 06-29-2010 04:38 PM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
The Driver Side River Nutzoids General Yaris / Vitz Discussion 7 12-14-2006 01:11 AM
