Old 10-20-2014, 05:07 PM   #1
Echospeed
Drives: 2002 Toyota Echo Coupe
The outer edge at the bottom.
Echospeed is offline   Reply With Quote
Old 10-20-2014, 06:43 PM   #2
I would loosen the frame bolts and see if there is any play that will let you pull that end in. You just changed the rotors, not the calipers as well?
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Rim 13" or 14" Yaris Hatchback 2008 Bearmantle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2013 12:11 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
