#19 | |
OP, edit one of your photos to draw a circle around the exact spot where contact is being made between caliper and rim.
#20 |
![]() Drives: 2002 Toyota Echo Coupe Join Date: Oct 2014
Turns out it was a badly bent rim causing the trouble. It got rotated to the rear for now. That being said, is a replacement steelie worth it or should I just go on and get new wheels? If so, what would be a safe dimension to move up to for a slightly larger wheel size?
#21 |
Try your local salvage yard. There's usually cheep used ones available.
Sent from my iPod Touch |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| Rim 13" or 14" Yaris Hatchback 2008 | Bearmantle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-19-2013 12:11 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| Rubbing Issues | RacerFreakXXX | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 05-12-2010 08:26 PM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 03:25 PM |
