#19 | |
. I went to Sears. Their Series 35 wouldn't fit either, but they OK'd putting in a Series 26R (1 year guarantee)..their cheapest battery. That battery lasted exactly 3 years to the day and 87.000 + miles. By that time, Sears had eliminated their 1yr Guarantee battery, and the 2yr guarantee battery was $20.00++ more than the previous 1yr battery. Wal-Mart still had a 1yr Guarantee 26R that was the same price the Sears 1yr Guarantee battery had been 3 years before that. I took the car to a different Wal-Mart from the one I'd taken it to 3 years before that. I had to go through the tech trying to put in a series 35 (it didn't fit again...same as 3 years before that), until he then agreed to put in the 26R. That 26R only lasted about 16 months and about 49,000 miles. By that time, I knew CTScott uses the NAPA Legend in his Yarii and decided to get the NAPA Legend.....$121 and change and then $10 to a local shop to put it in. The cost of the previous Sears battery, plus the cost of the Wal-Mart EverStart 3 years later, plus installation for both = literally only a few pennies (less that a dollar) of difference from the $121 and change + $10 installation for the NAPA Legend. The NAPA Legend is well worth it....a great battery. The NAPA Legend series 35 fits in the Yaris. The reason the Wal-Mart series 35 doesn't fit stock isn't that it won't 'sit and have enough clearance', it's that the clamp won't fit over the top of the battery. Some people have customized the clamp to get it to fit, but isn't buying a battery that fits an easier proposition?
#20 | |
![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
#21 | |
You can't really find the Panasonic battery anywhere. Even our local Toyota dealers don't sell then. They actually sell batteries manufactured locally. |
#22 |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
I'm still on my stock Toyota battery. It felt a bit weaker last year so I popped open each tab to access the cells and topped it off with some distilled water, put the tabs back on, shook it up, and put it on a slow charger for a few days. Seems to be running stronger so far but then again I live in an area where the weather doesn't get too extreme.
#23 | ||
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
#24 | |
play every day
![]() The last red top in my truck lasted 10 years, replaced it with the same kind. When I bought a new truck, I moved it. What I like about Optimas are that they will NEVER NEVER EVER leak even one tiny drop of acid... even if they're installed upside down. My 2012 Yaris is still on the factory battery, but when the time comes, it'll get an Optima. Greg |
#25 |
I suspect your Toyota dealer can get one if you REALLY pushed hard. When the battery in my IS300 died, the dealer told me they can get the Panasonic battery if I REALLY just HAD to have the factory original battery. It was in their catalog but it cost $$$$$. It's been a while but, a generic lead acid battery was about $70. An AGM battery at O'Reilly (which I bought) was about $150 (?). The factory Panasonic was, I think, something like $400...
#26 | |
#27 | |
#28 |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
did it today
I signed up with Napa and they sent me 10% off coupon and we got the Napa 7535 battery. Around $109 with tax. Good stats, fits perfect. Also if it is good enough for CTScott, it is good enough for me. We did not want to wait for the old one to fail. It was starting to swell as old batteries do and it was 6 years old.
BTW, what do you guys think about battery protectors (felt washers) and synthetic Dielectric grease placed on the terminals after hookup? |
#29 | |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
![]() TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges... |
#30 |
#31 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
I always put new red and green felt washers on the battery terminals when I replace my batteries plus dielectric grease. Have had little or no corrosion on the battery terminals for the life of the battery.
Roy |
#32 |
Earlier tonight I decided to start my 2007 Yaris (in the garage, with the door open) for the first time in 2 weeks (since driving home after the fender bender on 10/7/14). I crossed my fingers before turning the key. I needn't have. It started up as if the last time I'd driven it was a few minutes ago
#33 | |
My duaghter drives her Camry 40,000 miles a year. She has massive problems with battery terminal corrosion. Theres two inches thick corrosion on top of the battery and corrosion on a nearby computer and the fuse box. Unfortunately I didnt put wheel bearing grease on her battery when she got it. My wife drives her Camry about 12,000 milesa year and has moderate corrision problems. About every two years the terminals need to be cleaned and flushed with baking soda solution if you dont grease them up good. But its only a tenth as bad as my daughters car. My Yaris gets ~5000 miles a year and has zero problens with corrosion even if the terminals arent greased.
#34 | |
but at around 4 weeks, now it should be a little harder to start. At least, under extreme cold (-30c/-22f) |
#35 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
Hey all, quick question. I've read here on the forum about quite a few people getting 4+ years out of their OEM Yaris battery. Isn't that really good? Why not just buy another OEM battery from Toyota if they last so long? Is there something I'm missing?
My 2008 Yaris' car battery finally died on me after 6 years (61k) and I'm thinking if it lasted that long, shouldn't I just get another OEM battery from the dealer so I can get a lot of years out of it? My local dealership has a coupon for a Toyota True Start 84 month battery for $129, installed. Is that a good price? I'm assuming that's the same OEM battery that comes with the Yaris, right? Is there any specific reason why I should avoid the OEM/Toyota True Start battery and instead go with a name brand like the Napa Legend that's been mentioned here? |
#36 |
The OEM battery is a Panasonic battery which can't be found here. Toyota dealers resell locally made batteries usually.
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 02:14 AM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-01-2009 11:12 PM |
