Old 10-26-2014, 06:47 PM   #1
Darkhorse6
Drives: 08 5dr HB
been trying to figure this one out for 2 days now. I bought the avital keyless system from a-1 electric. I have an 08 yaris hatch with central locking (lock button in between the front seats)... I can get it to unlock all the doors and flash the parking lights, so everything seemed to be going well.
No matter what I do, I can't get it to lock the doors. I followed the DIY on here and connected the unlock wire to the green wire in GD1, my lock wire is connected to the thin brown wire. Is it possible the brown wire in my car doesn't carry the lock signal??
Darkhorse6 is offline   Reply With Quote
Old 10-26-2014, 09:05 PM   #2
Take a look at the revised one that I put together after installing it one the first one of mine. There is an issue with this one where if you have operated the lock on the door manually, the remote will not work properly. The correct wires for lock and unlock are noted in mine (if memory serves me correctly, it is only one of the two that is incorrect):
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 10-28-2014, 02:18 PM   #3
Darkhorse6
Drives: 08 5dr HB
Hi CTScott,
Thanks for the reply. I did find your other post and had changed my unlock wire from orange to green. So everything works for UNlocking. The lock wire in the diy and in your post is the brown wire in gd1 pjn 5. I did notice in another post in the link you provided that there may be another LOCK wire in that GD1 harness. Could that be the issue?
Old 10-28-2014, 03:34 PM   #4
Hi CTScott,
Lock is definitely the brown wire on GD1. Try touching a jumper wire from it's pin to the chassis ground bolt and if it locks when you do so, either your connection to the wire is bad or your device has a bad output relay.
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 02:29 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 11:27 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 03:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 11:46 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 10:57 AM
