Old 10-29-2014, 04:31 PM   #1
Originally Posted by BoostedTRD View Post
CTScott by any chance do you have a write up or instructions on how you modified the stock fuel pressure regulator to increase the pressure from the stock 41-45 psi to an amount corresponding to the max boost?
I built a test fixture that allows me to run a stock fuel pump and test an adjusted regulator. I actually tighten the spring in the regulator to make the change, but the test fixture is essential for doing so.
Fuel pump djgab101 Performance Modifications 5 02-28-2012 12:02 PM
Aftermarket Fuel Economy Gauge? johnstevens Fuel Economy Forum 4 05-03-2009 11:48 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
