Old 10-30-2014, 09:45 AM   #1
dobrik
Drives: Yaris 2013 1.33 CVT
I would consider the sound in the video to be pretty normal, particularly for the 1.33L, which to me is a bit more ticky than the 1.5L.
Thanks Scott, what about irregular tap-tap....tap-tap-tap-tap...tap-tap-tap-tap-tap-tap...and so on (cleary heard from 15s)?
dobrik is offline   Reply With Quote
Old 10-30-2014, 11:06 AM   #2
Even that sounds normal. If anything there might be a slight exhaust leak from the gasket between the exhaust manifold and the mid pipe.
Old 10-31-2014, 07:26 AM   #3
dobrik
CTScott you know you're right, finally I was able to pinpoint where the tapping comes from, exhaust manifold, under the heat shield, that's why it's very clear could be heard from the passenger side wheel arch. Actually the same tapping but very weak i can hear from my rav4, so I guess it some kind of toyota's feature. Reminds me my friend's 2003 corolla that had sounds from intake manifold....
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Really Bad Engine Sludge... monchito18 DIY / Maintenance / Service 27 05-14-2014 11:47 AM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
engine swap update Adriaan Canada 5 03-03-2009 06:21 PM
