Old 10-30-2014, 10:54 AM   #1
bronsin
bronsin's Avatar
check under the hood for red coolant stains indicating a leaking watre pump every 6 months.
grease battery terminals with wheel bearing grease.
clean leaves and debris on air intake under the hood for interior air intake
manual oil change unnecessary at your interval
valve clearance interval 60k miles. Probably not needed either.
your coolant change interval is too often. see owners manual.
have interior of car cleaned twice a year and car washed four times a year.
Otherwise sounds excellent!
Old 10-30-2014, 12:52 PM   #2
tmontague
tmontague's Avatar
thanks for the response. I was trying to find info regarding the red coolant recommended change vs the super long life pink. The best I could find is that red is good for 30,000 miles and pink for 50,000 miles. I figured i'd rather play it safe, that being said I'd rather stretch out the interval is safe to do so.
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
60K Mile Maintenance Pattycake DIY / Maintenance / Service 20 11-17-2009 02:34 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
