Old 10-30-2014, 04:22 PM   #1
gabriel2012
Drives: 2011 Base Sedan
You can use a small piece of wire or a small paperclip to do the jumping. If the car is still under warranty it should definitely be covered. You can also go to the "recalls" section of Toyota's website and plug in the VIN to find out which apply to it.
thanks for the tip scott, managed to reset the airbag light, I couldnt read the code though.
I took it to my friends body shop today and he found that the yaris had been in a small impact on the drivers rear side. He did say there was no frame damage and the repair was done properly(so good I didnt even notice it), I told this to the owner and haggled him down to 8k. My guy looked at every other inch of the car and couldnt find anything else wrong with it. All VIN stickers are present so I pulled the trigger
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too!
gabriel2012 is offline   Reply With Quote
Old 10-30-2014, 08:20 PM   #2
Nice. If it cleared and doesn't come back, then the problem was likely resolved, but they didn't reset the SRS ECU.
Old 11-03-2014, 07:49 AM   #3
gabriel2012
So far so good, after they guy had it reset(don't know how, but I do know the light wasn't unplugged from the cluster and everything else is acting good)
I've driven 250 miles with and without a passenger and the system has been behaving as expected. (weight sensor working when passengers sit/exit the vehicle).
I checked for any recalls and for my VIN there are none.
The things the car had when I bought it:
Rear drivers water leak by taillight/trunk seem - Fixed with silicon by applying a nice big coat outside and inside the vehicle.
Rear drivers side bumper reinforment bar support - It was a bit smashed for the impact, I ordered a new OEM toyota(body shop buddy gets 40% on all OEM parts) one along with the shock absorbers for the bar.
Acc belt squeak - Gone after re adjusting the tension on the alternator, belt seemed fine.
I'm in love with this little sedan after having my 07 HB totaled
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Man hits 1 MILLION MILES in Ford F-250... in four years!!! Kal-El Off-topic / Other Cars / Everything else Discussions 6 10-30-2010 10:19 AM
Also thinking of buying a Yaris TwoBearWisconsin New YARIS Purchase Forum 34 10-13-2009 02:11 AM
What's ur longest drive in a Yaris without stopping(cept gas)? Yawesh General Yaris / Vitz Discussion 46 04-21-2009 01:36 PM
