Old 11-03-2014, 10:17 PM   #1
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Originally Posted by tmontague View Post
I currently do the following:
-Remove and re-install control arm bolts and cover in grease
-Oil and filter change every 8,000km w/ synthetic oil
-brake service ever year (re lube slider pins, clean pads and rotate pads if necessary)
-Replace MTF every 2 years w/ synthetic ~40,000km
-coolant flush and fill w/ Toyota Red every 2 years~40,000km
-Spray bolts and rust prone parts on underbody ever 6 months with an anti rust compound
-inspect and clean PCV valve every year
-bleed brakes every year
-bleed clutch every year and lube pivot points
-check valve shim clearance every 40,000km
-wax car every 6 months
good idea
good synthetic can go double that
I thought I was the only person rotating brake pads? LOL!
overkill
I thought it was every 3 years?
good idea
good idea
good idea
not sure?
way overkill (100,000 miles is more like it, especially as not easy to adjust the clearance).
good idea (if you wash first)
jack black is offline   Reply With Quote
Old 11-04-2014, 12:18 PM   #2
tmontague
tmontague's Avatar
I just realized that 40,000km is definitely overkill, I'll likely go 75,000km-100,000km before I check again.
On a side note I noticed an oil stain on the outside of my engine coming from the valve cover. I checked the bolts and had to re-torque them as the bolts in that area had come really loose. The seal was fine when I re installed the valve cover last summer so I'm going to clean it up and see if the oil comes back.
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
60K Mile Maintenance Pattycake DIY / Maintenance / Service 20 11-17-2009 02:34 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
