Old 11-05-2014, 09:11 AM   #1
tmontague
tmontague's Avatar
The other night I tried squeezing the top rad tube until the coolant was at the top of the filler hole. I then would put the cap on and than release the hose I was squeezing as I figured this would create negative pressure and suck coolant from the reservoir. I could hear what sounded like coolant being sucked back into the top but when I opened the cap the coolant level was back to where it was before.
I think I'll just leave it for now as it isn't causing any problems and maybe over time is will normalise and coolant will be back at the top of the cap.
Various problems with service at shop (green coolant and accelerator rattling noise) LilyOfTheYaris DIY / Maintenance / Service 4 04-08-2014 10:31 PM
Khameleon Coolant? LilyOfTheYaris DIY / Maintenance / Service 18 04-08-2014 10:27 PM
Alternatives to Toyota "pink" super long life coolant Camberix DIY / Maintenance / Service 10 03-30-2011 11:42 AM
coolant reservoir? toad DIY / Maintenance / Service 10 11-02-2010 11:02 AM
Check your coolant bottle UTVitz DIY / Maintenance / Service 13 12-16-2009 09:13 PM
