If you pull the cover off of the inside of the hatch you will have access to the rear wiper motor. Removing the nut that mounts the wiper arm allows you to then completley remove the rear wiper motor assembly. The cover for the gear box assembly can be removed giving you access to the gear train. You may just find that the shaft seal leaked and that you just need to regrease the gears.
In a worst case you should be able to find a replacement on ebay or from a local junkyard. I am not sure about the MK1 prices, but I have seen MK2 rear wiper motors sell over here for $50 - $100.
| Wiper Motor rear | k3nty | DIY / Maintenance / Service | 15 | 08-24-2014 09:07 AM |
| Sedan REAR WIPER DIY??? | ChitownY@Ris | Cosmetic Modifications (Exterior/Interior) | 9 | 02-04-2013 09:53 AM |
| rear window wiper | yaris2010RS | DIY / Maintenance / Service | 7 | 03-25-2010 02:05 AM |
| Rear Windshield Wiper - LB | KittenRD | General Yaris / Vitz Discussion | 2 | 02-21-2010 10:19 PM |
