![]() Drives: Toyota Yaris 2010 Join Date: Feb 2012
Can't seem to post an image with an url here, posts are being deleted
Sent you a PM Thank you |
#2 | |
Your original questions were: Trying to install Valet 561T in 2011 Prius Sedan AT with Factory Alarm I think i figured out the most of the things except for few On the 4 Pin Satellate Harness there are few wires that aren't clear for me where to connect 1. Accessory Trigger ( does it go to Conn 8 Pin 2 White wire) 2. Wire 3 Starter Trigger ( does that go to Conn D8 Pin 7 ) And another thing Heavy Gauge Relay Sattelite 1. Wire 2 Purple do i tap in to D8 Pin 7 Black starter wires ? 2. Wire 3 Orange do i tap in to D8 Pin 2 White Accesory wire? Accessory and starter trigger on 4 pin satellite are not needed. On the heavy gauge one: 1. To Ignition 1 on the ignition switch connector. 2. To both black wires on the ignition switch connector. 3. To Accessory wire on the ignition switch connector. 4. To power feed on fuse panel 5. To Ignition 2 on the ignition switch connector. (You will also have to go through the configuration of the remote starter to select ignition, rather than starter function. 6. To power feed on fuse panel
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
