Old 11-10-2014, 12:27 PM   #1
Eduardo_mty
one question.
i will take the + wire, from reverse light, i will run from back to front.
one pin on the harness, is the reverse light trigger, then,
i will connect .. + wire from reverse light, + red wire from harness and +wire from pin trigger?
this is correct?
Eduardo_mty is offline   Reply With Quote
Old 11-10-2014, 12:49 PM   #2
Eduardo_mty
pictures
Old 11-10-2014, 01:21 PM   #3
Originally Posted by Eduardo_mty View Post
one question.
this is correct?
I would think that the + wire should get ignition switched +12 V power and the reverse wire would connect to the red back-up light wire. Does the documentation explain the pin trigger? I would think that it would be a separate way of turning the camera on (like when you are not going in reverse).
Old 11-10-2014, 01:26 PM   #4
Eduardo_mty
reverse trigger instruccions
http://www.autoharnesshouse.com/19867_add.html
Old 11-10-2014, 01:31 PM   #5
Ah, the reverse trigger is just the opposite of what I was thinking - It is an input to the head unit to tell it that the car is in reverse.
Old 11-10-2014, 01:34 PM   #6
Eduardo_mty
the trigger pin, is the #2 from left to right..opposite the "security clip"
Old 11-10-2014, 01:49 PM   #7
Eduardo_mty
harness position
