Old 11-10-2014, 12:29 PM   #1
nortonfb
Drives: 2007
Are you having issues?
What do your plugs look like?
Norton
nortonfb is offline   Reply With Quote
Old 11-11-2014, 02:40 AM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Norton
Well the car sometimes has extended crank before it starts (sometimes).
I did get an engine light a few weeks ago which i reset by pulling the negative terminal off and putting it on.
The car can accelerate up to speed OK. But seems a bit sluggish and the mpg is down a bit.
I purchased new coils and iridium NGK spark plugs.
Old 11-11-2014, 09:31 AM   #3
tmontague
tmontague's Avatar
depending the position the engine stops in, it can feel like there is an extra turnover on the next start up. I've noticed this before occasionally.
Did you pull the code from the CEL? This would help give you a better idea if it was a specific cylinder misfiring. If you haven't changed the plugs in a long time (>80,000km) then change those and see how it runs. Chances are if it was a bad coil, it would run rough. You can tell what cylinder it is by running the engine and pulling the coil off each cylinder at one time. If the car doesn't change how it runs when a certain coil is taken off then that specific coil is likely not firing properly. Better to just pull the CEL though.
The lower MPG could be a few things, I know where I'm from I've recently gone from an avg of 5.1 L/100km to 5.45 due to colder temps and change in fuel composition for the winter. Check your plugs and see how they look as well
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Ignition coil Jlively Performance Modifications 4 10-14-2014 08:28 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
