Old 11-10-2014, 06:39 PM   #1
camry09
Drives: Toyota Yaris 2010
Alright maybe im missing something, but so far this is the only thing that ive found
IMPORTANT! This product is designed for fuel-injected, automatic transmission vehicles only.Installing it in a standard transmission vehicle is dangerous and is contrary to its intended use.
Thank also this part
Connect this wire to the toggle (override) switch as shown in Figure A. Connect the other wire from the toggle switch
to the PARK/NEUTRAL switch in the vehicle. This wire will test with ground with the gear selector either in PARK or
NEUTRAL. This will prevent the vehicle from accidentally being started while in a drive gear. This input MUST rest at ground
in order for the remote start system to operate. Connected properly the vehicle will only start while in PARK or NEUTRAL.
In some vehicles, the PARK/NEUTRAL position switch activates a factory starter lock-out that will not allow the
starter to operate in a drive gear. In these vehicles, connect this wire to the toggle switch as shown in Figure B.
Connect the other wire from the toggle switch to chassis ground.
Do i just ground this wire and call it a day?
From guys that did this install on AT can you please point me on the right track
thank you
camry09 is offline   Reply With Quote
Old 11-10-2014, 06:58 PM   #2
thank you
Looking at the configuration guide where you can get into the menus and change different settings, it looks like this one does not have a setting for it. I just installed a Viper remote starter (also made by DEI, like Valet) in my sister's Tacoma and had the same issue, but changing the default MT setting to AT solved it.
For yours, just ground that wire.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
