![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Well the car sometimes has extended crank before it starts (sometimes).
I did get an engine light a few weeks ago which i reset by pulling the negative terminal off and putting it on. The car can accelerate up to speed OK. But seems a bit sluggish and the mpg is down a bit. I purchased new coils and iridium NGK spark plugs. |
#2 | |
Did you pull the code from the CEL? This would help give you a better idea if it was a specific cylinder misfiring. If you haven't changed the plugs in a long time (>80,000km) then change those and see how it runs. Chances are if it was a bad coil, it would run rough. You can tell what cylinder it is by running the engine and pulling the coil off each cylinder at one time. If the car doesn't change how it runs when a certain coil is taken off then that specific coil is likely not firing properly. Better to just pull the CEL though. The lower MPG could be a few things, I know where I'm from I've recently gone from an avg of 5.1 L/100km to 5.45 due to colder temps and change in fuel composition for the winter. Check your plugs and see how they look as well |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Ignition coil | Jlively | Performance Modifications | 4 | 10-14-2014 08:28 PM |
| Door trigger for Rear Right RR door missing | enve1160 | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 12-29-2010 10:14 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
