#1 | |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
Most of the banjo feed kits do have built in restrictors, but they typically are offered in separate choices of 1.5mm for journal bearings and 1.0mm for ball bearings.
Do you think I'm safe with mine? another question, what's wrong with running the return line to the oil pan?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin Last edited by Ryze268; 11-11-2014 at 01:00 PM. |
Just check the size of the hole in it. If it is too large then you maintain pressure through the turbo, which can cause oil seepage through the bearing and hence smoke out the exhaust. The return oil line can also cause the same problem if the oil exiting meets resistance (like pumping up through a puddle of oil). That and frothing of the oil are why you want the return above the level of the oil in the pan.
#5 | |
I'm also looking for a base tune that has the maf clamp already set up for the F/IC 6
#6 | |
For the MAF clamp it is best to follow the procedure shown in the F/IC documentation for doing so, as your air intake setup may provide different readings than on another car.
#7 | |
I was watching the AEM tutorials and thy said to install the FIC and collect data while the car is stock first so that's what I'm trying to do.
| Quick question for those who know................. | NEexpat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-21-2012 01:38 PM |
| Quick question | StephenMenace | Third Gen Yaris General Discussion | 4 | 01-27-2012 07:20 AM |
| Just a quick Oil question | mr_miles | DIY / Maintenance / Service | 19 | 11-04-2011 11:31 PM |
| Quick Oil Question | nickhjort | Performance Modifications | 5 | 04-27-2010 08:51 AM |
| ZPI Turbo question? | localnet | Forced Induction Forum | 15 | 06-29-2007 06:06 AM |
