Just check the size of the hole in it. If it is too large then you maintain pressure through the turbo, which can cause oil seepage through the bearing and hence smoke out the exhaust. The return oil line can also cause the same problem if the oil exiting meets resistance (like pumping up through a puddle of oil). That and frothing of the oil are why you want the return above the level of the oil in the pan.
| Quick question for those who know................. | NEexpat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-21-2012 01:38 PM |
| Quick question | StephenMenace | Third Gen Yaris General Discussion | 4 | 01-27-2012 07:20 AM |
| Just a quick Oil question | mr_miles | DIY / Maintenance / Service | 19 | 11-04-2011 11:31 PM |
| Quick Oil Question | nickhjort | Performance Modifications | 5 | 04-27-2010 08:51 AM |
| ZPI Turbo question? | localnet | Forced Induction Forum | 15 | 06-29-2007 06:06 AM |
