Old 11-12-2014, 06:39 AM   #1
You pretending to be a 10 yr old sitting in a car, shifting, and making neat power shift sounds with your mouth?
It means nothing. Sometimes when a car is sitting at rest, engine off, the gears will be aligned and you can throw the shifter through the pattern. Sometimes the are not aligned and you cannot engage the shifter without pressing the clutch.
Old 11-12-2014, 02:52 PM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I've had other manual cars before i can shift 1st,2nd,3rd,4th, to 5th to reverse with the engine off and back no problems. But with this car i can but sometimes it refuses to go to any gear with the car is not running you know me just playing around with it.
I was thinking something is wrong with the gearbox. Apart from having a notchy 2nd and 3rd gear. It's funny because in the cold it's sometimes smooth and other times it's notchy galore. LOL.
Time to replace it??
Old 11-13-2014, 01:46 AM   #3
nookandcrannycar
My little cousin did that in my blue Yaris when she was seven.
Old 11-13-2014, 04:07 AM   #4
eseibel67
eseibel67's Avatar
Drives: 2007 Yaris
What it means? Your trans is functioning normally. Congrats.
Wanna prove it? When on flat ground in neutral, release the parking brake. ever so lightly pull the shifter towards second gear. Now open the door, put your left foot on the ground, and while still holding the shifter towards second push the car backwards using your foot. Before the car even rolls 1 inch, the trans will slip into second gear like butter.
eseibel67 is offline   Reply With Quote
Old 11-27-2014, 05:10 AM   #5
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
"vvvvvvrrrrr - choo (blow off valve)
Vrrrrrrrrrrr - choo choo BANG! (flames from exhaust)"
Hahahahahahaha
Sent from my HTC Explorer A310e or my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George.
vivalaflam is offline   Reply With Quote
Gearbox breaks at 110,000km on Yaris 2007 sven337 DIY / Maintenance / Service 10 07-26-2014 07:06 PM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
