Old 11-12-2014, 10:03 AM   #1
tmontague
tmontague's Avatar
Originally Posted by SonicGuppy View Post
Howdy. New here. Getting acuainted with the motor. Any suggestions on where the PCV Valve is? Thanks
Some people replace the valve since it's relatively cheap (at least in the states) up here in the North it's a bit more pricey so I just shoot some brake cleaner through it every 20,000km and it always make the valve rattle more inside. I have never had an issue with it completely jamming. Even on my fiancee's '02 Echo which burns oil due to worn piston rings (338,000km).
I have a DIY oil catch can installed right after the PCV and there is never more than a half tsp of oil in there at each oil change.
Careful tightening the valve back it doesn't need to be cranked very hard and since the block is aluminum it has the potential to strip
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 11:13 AM
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 05:05 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-17-2013 12:06 AM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 09:55 AM
