Old 11-13-2014, 03:11 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
The resistors are not a bad idea to add. As long as you tie the other end of the resistor to a good ground it doesn't matter where you do so.
Would the best ground be straight to the negative terminal of thee battery?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 11-13-2014, 03:26 PM   #2
Yes, but that is not necessary. Any ground bolt or ground wire is sufficient.
Old 11-13-2014, 03:54 PM   #3
Ryze268
Ryze268's Avatar
Do you have a specific way of setting up the resistor contrary to "parallel to the cam and crank sensor inputs and tie them into their respective grounds with the resistors."
A quick diagram would b helpful. I'm really disappointed that the F/IC is turning out to be such a headache.
It would feel great if we could finally get it working right
Quick question for those who know................. NEexpat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 11-21-2012 01:38 PM
Quick question StephenMenace Third Gen Yaris General Discussion 4 01-27-2012 07:20 AM
Just a quick Oil question mr_miles DIY / Maintenance / Service 19 11-04-2011 11:31 PM
Quick Oil Question nickhjort Performance Modifications 5 04-27-2010 08:51 AM
ZPI Turbo question? localnet Forced Induction Forum 15 06-29-2007 06:06 AM
