Old 11-14-2014, 12:54 AM   #1
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
I used.a spark plug socket. If you're going to do it yourself, make sure to stabilize the.extension (applying pressure towards the block) as you're unscrewing. Otherwise, you'll end up doing what I did.
MyzticZ3r0 is offline   Reply With Quote
Old 11-14-2014, 12:56 AM   #2
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
thanks im changing plugs soon in my 2007 yaris. Only 56000 miles but I do not want plugs seizing in aluminum head.
Toolaholic is offline   Reply With Quote
Spark Plugs walt101786 DIY / Maintenance / Service 2 12-12-2011 01:00 PM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
