![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
Hello
The clear white plastic part that hold the rubber gromet of the hatch is loose,the water can leak inside the headliner. I searched the catalog of parts but without luck, the part itself donīt have any marking that indicate a Toyota code XXXX-XXXX. Silicone sealant and 3M tape cannot hold in place, Japanese Yaris 2013, sorry for the bad english ![]() Thanks for any help |
I usually find that the local Toyota dealer can give that info in 5 minutes. try that.
That white part is considered part of the complete hatch wiring harness. You can't purchase it separately from Toyota.
![]() ![]() Drives: 2013 Yaris LE 5Dr Join Date: Nov 2014
You can make something out of hose sealer and silicon from Lowe's or Home Depot.
#5 | |
You would have a difficult time making something to replace it and particularly finding a sealing compound that will stick to the painted metal and the rubber and form a completely waterproof seal (particularly for the O.P., who is in Panama, where it is hot and wet).
#6 | |
Good luck. |
Thanks for all the responses
I will evaluate all the options available: 1. Buy the whole harness 2. Search in the junkyard, some new yaris have crashed 3.Another post have a lead for possibles replacements, partial Part Name Code (82819-XXXXX) that will investigate more. The best advice I can give is: Be careful when installing any reverse camera |
![]() ![]() ![]() Join Date: Sep 2014
Ctscott do you know the part number of hatch Wiring harness.
Joell i did the same "error" when i try to install reverse camera Last edited by Eduardo_mty; 11-14-2014 at 12:57 PM. |
#9 | |
82184-52320 82184-52340 82184-52350
I found it, www.toyotapartsoverstock.com $82.41 usd
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
what is the best way to remove that plastic part when removing the reverse camera ?
Squeezing the tabs from below is the only way to remove it without deforming it.
Partially, or get your hand up between it and the roof.
Update: I take the broken part to a 3D printing shop, they scanned and printed in black ABS, cost $30 dollars.
Do you have a finished printing part.
Where are you located ? |
Picture from finished part printing
This is the finished printed part, i dont have the computer archive of the 3D model.But you can search locally for some place that can help you: http://www.3dhubs.com/3dprint
| Top glove box part number? | Nips | Cosmetic Modifications (Exterior/Interior) | 6 | 02-24-2012 11:39 AM |
| Yet another cabin air filter part number... | Goose | DIY / Maintenance / Service | 0 | 05-05-2010 05:15 PM |
| Part Number?? | nick1983 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 04-12-2007 01:43 PM |
| A quick favor... I need a part number | ChinoCharles | General Yaris / Vitz Discussion | 5 | 04-10-2007 08:36 PM |
| HELP: JDM Armrest Console Box part number | GabL | Cosmetic Modifications (Exterior/Interior) | 7 | 10-24-2006 11:12 PM |
