Old 11-15-2014, 12:25 AM   #1
edavidrock
Drives: Yaris
Hi Scott,
My yaris rear doors don't have any holes to take wires out from the inside the door. What do you recommend me to do? Can I drill a hole?
Thanks
edavidrock is offline   Reply With Quote
Old 11-15-2014, 06:36 AM   #2
Originally Posted by edavidrock View Post
Hi Scott,
Thanks
Hmm. I have never dealt with adding it to a 5 door Yaris. If you drill the door and frame you will need some type of a wire boot to prevent water from entering either side.
Old 11-15-2014, 09:50 PM   #3
edavidrock
Drives: Yaris
hi Scott, here is the picture of the unused prong plug after removing rubber bush that was connected to the body. Can I use that?
And third picture shows the fuse and plugs under the dash boar. Could you please let me know which one is the +12v?
Thank you
power windows
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
Power window mamun22s DIY / Maintenance / Service 1 08-30-2012 07:35 AM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 06:27 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
