Old 11-17-2014, 03:12 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
CTscott you are spot on. I disconnected the AC ecu and it read correctly !
So my question is now, can I just cut the thermistor wire that goes into the AC ECU and connect it to my meter instead ? I dont have the fancy climate control in my car, just the normal manual AC controls so I am thinking that the AC ecu doesn't really need to know the outside ambient temp.
JudgeM is offline   Reply With Quote
Old 11-17-2014, 06:50 AM   #2
The manual AC ECU does want the ambient temperature input as well. I believe it uses it to determine the duty cycle for the compressor to avoid freezing the evaporator when running it for defogging in colder temperatures.
You can try it though as see how the AC works. Another option would be to connect a fixed value resistor to the AC ECU pin and fool it with a constant outside temp value.
Old 10-08-2018, 09:09 AM   #3
ojeysky
Drives: Sedan Yaris 2010
Hello CTScott this is what happens in my case, i do not have the ambient sensor on but my scanner constantly reads that ambient temp is 81C, i wonder if 81 is a good value to have optimal coolness in the car. Outside temp is normally between 35 and 45C
ojeysky is offline   Reply With Quote
Old 11-18-2018, 07:54 AM   #4
ojeysky
Hello CTscot,
I got the sensor at Amazon (did a vehicle fit check on Amazon which passed before I ordered it) find attached picture but it doesn't seem to fit.
Is it possible that I am looking at the wrong place for the sensor?
Regards
"Catalyst mon" incorrect on ODBII reader Pingouin DIY / Maintenance / Service 0 11-09-2011 02:51 AM
ATX temperature overheating? yaryarbing Fuel Economy Forum 7 05-07-2011 09:24 AM
Temperature Guage install bieniman DIY / Maintenance / Service 3 03-12-2009 02:45 PM
Water temperature Bob_VT General Yaris / Vitz Discussion 11 11-03-2008 03:17 PM
