#1 | |
You can try it though as see how the AC works. Another option would be to connect a fixed value resistor to the AC ECU pin and fool it with a constant outside temp value.
![]() ![]() Drives: Sedan Yaris 2010 Join Date: Dec 2017
Hello CTScott this is what happens in my case, i do not have the ambient sensor on but my scanner constantly reads that ambient temp is 81C, i wonder if 81 is a good value to have optimal coolness in the car. Outside temp is normally between 35 and 45C
Hello CTscot,
I got the sensor at Amazon (did a vehicle fit check on Amazon which passed before I ordered it) find attached picture but it doesn't seem to fit. Is it possible that I am looking at the wrong place for the sensor? Regards |
| "Catalyst mon" incorrect on ODBII reader | Pingouin | DIY / Maintenance / Service | 0 | 11-09-2011 02:51 AM |
| ATX temperature overheating? | yaryarbing | Fuel Economy Forum | 7 | 05-07-2011 09:24 AM |
| Temperature Guage install | bieniman | DIY / Maintenance / Service | 3 | 03-12-2009 02:45 PM |
| Water temperature | Bob_VT | General Yaris / Vitz Discussion | 11 | 11-03-2008 03:17 PM |
