Old 11-21-2014, 01:12 AM   #1
lh59
lh59's Avatar
Drives: 3 dr 1.3 2NZ
Realized this is an old thread, but can I reach throttle body by just unscrewing F and clean it from there? When my aircon is on, the engine sometimes sputter and dies while on idle.
lh59 is offline   Reply With Quote
Old 11-21-2014, 06:18 AM   #2
Yes. You can access it pretty well just by disconnecting the intake hose. You will still want to open the butterfly to clean the inside as well. With the ignition on (but engine off) either wedge something against the gas pedal or have a helper press it to keep the throttle open for cleaning.
Old 11-22-2014, 08:38 PM   #3
lh59
lh59's Avatar
Thanks Scotty. I cleaned out the TB pretty good, but did have to unsnap some of the wire loom to move it out of the way. A world of difference it make to my rough idle. Completely gone!
Old 11-21-2014, 09:02 AM   #4
tmontague
tmontague's Avatar
That's all I did to clean my TB and it worked well. I used an old tooth brush and TB cleaner, kept the butterfly open and sprayed inside and then brushed any carbon out. It seemed to work well.
That was 15,000km ago and I noticed lately that my car seems to idle around 500RPM and then I can feel a slight rumble and it will rise up briefly to 600 and then back down. I wouldn't necessarily call it a "rough idle" but it is noticeable while being stopped most of the time. Anyone know the recommended cleaning interval for the TB? I'm surprised if a dirty TB is what is causing this issue since I cleaned it not that long ago. I'm also using an oil catch can FWIW.
Old 02-18-2016, 10:18 PM   #5
Sarvesh
Drives: Toyota Yaris 2012
Low rpm
Hi. I wanted to know if you were able to solve the low rpm problem? I am having the same problem in my Yaris. Cleaning the throttle body doesn't seem to solve the problem. Can you advise if ever you know the solution.
Sarvesh is offline   Reply With Quote
vitz high idle problem after cleaning the throttle body. dindy DIY / Maintenance / Service 20 11-07-2012 05:05 PM
Mass Air Flow Sensor & Throttle Body Cleaning Damian B DIY / Maintenance / Service 11 09-23-2012 11:00 PM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
