Old 11-26-2014, 02:48 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
just get some gorilla lock nuts. either ones with 1 lock nut, or all 4 lock nuts, or just basic type where a socket adapter is needed to remove.
As for springs, there is a diminishing return on getting stiffer springs as it relates to ride height. Did you already calculate the drop with those spring specs?
Check out my Build thread:
Old 11-26-2014, 03:11 AM   #2
TerenceCruz
Drives: 2011 Toyota Yaris
Sweet, I'll look into those lug nuts Jonathan. And as for the springs, what do you mean a diminishing return on getting stiffer springs as it relates to ride height? Sorry I'm having a brain fart and I'm sleepy lol. I basically just want 5" springs in the rear (so I can put my locks/perches back while being able to go as low) that are stiff enough to where I can have one or two people in the back without the spring compressing an inch. I want the lips of my wheels to be pretty close to my fenders when everything gets dialed in correctly. If I can find those stance coil springs you showed me, in 8k BUT in 5", I will definitely pick those up. If I go with the 6" that are available, once I put the locks/perches back on it, its max low would be the same height where I am at right now basically. So I want to get a shorter spring so I can even out that rear height cause my rear passenger side is about 1/4th of an inch higher remember?
TerenceCruz is offline   Reply With Quote
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 12:25 PM
2012 Vitz from the 2011 Tokyo Auto Salon CTScott Third Gen Yaris General Discussion 14 02-10-2011 08:06 AM
Is UA-NCP13 1.5L Manual Trans a Vitz RS? WesSunday General Yaris / Vitz Discussion 1 11-28-2010 10:47 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
A German Yaris/Vitz/Echo ;) we-to-11 Photo-Video-Media Gallery 5 06-27-2007 08:26 PM
