Old 11-27-2014, 11:46 AM   #1
tmontague
tmontague's Avatar
If it's a clunking from the wheel I'd recommend trying to move the wheel when it's up on stands and see if you have any play with the control arms or suspension.
However, it souds like the engine/clutch shudder the 1NZ-FE seems to be notorious for in the MT version. Try and bleed the clutch AS WELL AS THE SLAVE CYLINDER and see if that helps. I did this on mine last moth and it worked amazing for about 3-4 weeks and now it back half as bad a before. Only other fix is to just give it more gas until clutch warm up. Does this only happens for the first 10mins or so of driving?
Beeping while driver side door open Alpha DIY / Maintenance / Service 10 10-20-2014 06:42 AM
Detailed dealer pricing on the new, 2007 Toyota Yaris. tomjasz New YARIS Purchase Forum 3 08-11-2006 10:46 PM
