![]() Drives: vios Join Date: Apr 2014
Budget 1nzfe build (n/a)
Hi brother and sister !!
Im driving a toyota vios (yaris sedan) over here in singapore.. Recently started on a project for my vios.. Im going the n/a route as sticking a turbo charger in a n/a motor is illegal here.. Things i planned to do: High comp cp piston (11.5:1) Molnar rods Jun cam (264dur, 9.5lift) Bc valve spring & retainer Injen cai Dc header Custom 2" midpipe with a cat Hks muffler Going to be tune on unichip or emanage ultimate. Not going anything wild.. Wanted to ask the pro here what more should i add in to complete the build.. Like i say im nt going anything wild as this is a daily driven car.. Was thinking to go for: Bigger fuel pump (walbro) Fuel rail 1zz injector Bigger throttle body ?? Not should if the above is needed as its a n/a car, as i knw if im going turbo route i need a bigger injector.. Please fill in comments for me guys ^^ appreciate it.. |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
Have the rotating assembly balanced, it should save your bearings.
Take all the lifter buckets and have them polished, that should be worth a few RPMs and a bit of power. I would also coat the piston skirts on the CP pistons so you don't get bad cold start slap should also reduce some thrust friction and give you a few hp. |
Standalone... I don't see why you put so much money in the motor and not spend the extra 1k for a standalone to tune it with more parameters than a piggy back.
Hi all !! Tks for the reply
I'm planning to change the bearings also since its out.. And might be doing some head work to it too !! As for standalone, the market here in singapore is too small.. There isnt muh options when comes to tuning.. There isnt much tuner that know how to tune a standalone ecu.. Unless there are other options available.. |
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
Lightweight crank pulley!
| N/A Build !! | Gabwone | Tracking, Racing, Auto-X Forum | 18 | 10-23-2014 05:12 PM |
| Ecogeek's Build.... Teacher Budget! | Ecogeek | Photo-Video-Media Gallery | 36 | 04-19-2014 09:32 PM |
| Need a 1nzfe to build! | thatbryanguy | Willing to Buy by private party | 12 | 11-15-2013 07:29 PM |
| Help me me build my budget system =) | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 22 | 11-25-2008 02:33 PM |
