Old 12-15-2014, 06:30 AM   #1
tmontague
tmontague's Avatar
The filter is not around it - It is mounted into the block below it. The 1ZZs have two, where the 1NZs just have one. The leaking issue above is either a bad o-ring or a dented valve assembly.
Thanks, is it possible to clean the filter/screen on a 1nz? I'll have to clean the oil around it and see if it comes back again or stays clean. I may be in the same boat at the op.
Old 12-15-2014, 06:32 AM   #2
The filter only costs a couple of dollars, but if you remove it you can easily clean it with degreaser. The filter is very fine mesh with a plastic support frame.
Old 12-15-2014, 07:38 AM   #3
tmontague
tmontague's Avatar
And I'm assuming it is accessible to remove once the OCV is removed, or would one need to remove the valve cover?
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 04:05 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
gude-head-1NZ-FE GnomeBody Performance Modifications 222 03-25-2011 02:32 PM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 08:55 AM
