Old 12-17-2014, 08:40 AM   #1
tmontague
tmontague's Avatar
Originally Posted by duendeverde View Post
Mmmm ok, kind of ought :/
Today, I was parked for about 1-2 hour inside the car with the a/c on and the a/c for some reason the output of air was 2 low and the temperature was warm. When I got home and checked under the hood, the oil that was leaking from the ocv valve reached the top of the alternator near the pulley
I have heard other Yaris owners state that the a/c while no moving does not work nearly as well. I have yet to be stopped long enough (nor do I run my a/c enough) to notice this myself, but something to think about depending on how warm the air was coming out and how hot the ambient temp was of the outside air.
As a side note. After 150km of driving since I cleaned off the oil on the outside of the OCV it has yet to build back up. Likely it was just there from when my valve cover became loose. With that said if your's is leaking that much then definitely change it out as soon as you can as it's obviously damaged to be leaking that bad.
Old 12-17-2014, 10:41 AM   #2
duendeverde
Drives: Yaris 2010 Manual
Yep, just bought a couple of hours ago the OCV valve, In Puerto Rico temperatures fluctuates between 80-95 not very helpful LOL I'm gonna try and do a DIY of changing the OCV for purposes of Yaris Forum
duendeverde is offline   Reply With Quote
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 04:05 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
gude-head-1NZ-FE GnomeBody Performance Modifications 222 03-25-2011 02:32 PM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 08:55 AM
