DIYer
Drives: yaris 1.5 MT Join Date: Oct 2014
if you accelerate up to 6k rpm in first, and quickly change into 2nd gear letting off the clutch very quickly and the revs go down slowly instead of instantly then the clutch is going bad. another thing you would notice is the car shudders if you use too much throttle getting off the line.
#2 | |
Actually how I test a slipping clutch, stand still and rev to 3500rpm and dump the clutch in 3rd. It you don't stall, then your clutch is definitely slipping. |
DIYer
![]() ![]() Drives: Yaris 2010 Manual Join Date: Dec 2010
I bleed the slave cylinder with help (someone pressing the clutch pedal). The biting point return to normal (for me)
As for the clutch, in first gear if i take the clutch pedal out o know is going to stall since the car shudder
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
| Hang Time: Exploiting ECU Fuel Maps for Fuel Efficiency | BailOut | Fuel Economy Forum | 20 | 11-13-2013 08:11 AM |
| 7-17-09 Last Day for Time Attack Event @ CFRC | SAKU | Tracking, Racing, Auto-X Forum | 1 | 07-14-2009 02:10 PM |
| Oil change time intervals | PaidTimeOff | DIY / Maintenance / Service | 17 | 01-29-2009 07:14 PM |
