#19 |
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
engine: very small roughness on metal surface, will whip off in the first 1-2 hundred miles
oxygen sensor (sets the fuel/air mixture, therefore affects acceleration and fuel consumption): when new, it needs to get "burned" in order to operate to the specs. The hotter it gets, the faster it burns. I'd suggest, passing the first hundred miles, start shifting/keeping the revs higher than usually (above 4000rpm) and drive so 2-3 gas tanks. don't switch to synthetics before 1000 miles, a new engine needs to run on mineral oil |
#20 |
![]() ![]() ![]() Drives: Yaris 3dr Hatchback Join Date: Oct 2006
Hey guys, this is just a theoretical situation. Its not like I did it or anything.
But what if someone got their car with say, less than 15 miles on it. drove it slowly home for 15 miles. Then drove a 100 mile road trip in going some 110-120 the whole way, just because it was the first time he/she could. What kind of problems might he/she need to go get checked for at the shop? |
#21 |
![]() ![]() Drives: 07 Black Yaris 5D Join Date: Apr 2007
My Yaris is my 5th new car. I've broken in all my cars by driving them hard straight off the lot. My Yaris has 115 hard km's on it, WOT to redline in every gear. The reason I do this is because cars that go thru a hard break in period will be more powerful than a "normal" break in. All 3 of my SLK's were broken in this way, and was faster than the others at track days. I've never had any problems with engine reliability either.
rage2 My Yaris Diary - All about my new Yaris! My Blog - F1 News, Hotties, and Random Crap My Site - Beyond Car Forums |
#22 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
well, I agree for the first few thousand miles you should baby it and vary the RPM range, most of the breaking in is done at the factory these days, but you can never be to carefull...also, if you plan on shifting at higher rpms and flogging your car, keep in mind part of the break in process is seating the valves, and if the valves seat for the 3k-5k range and you constantly shift your yaris at 6k, its harder on the valvetrain and you wont get as much performance from the engine. I have not verified that on a newer car, but thats how they break in older muscle cars...I think the best way is to drive the car how you intend to drive it, but avoiding keeping it at the same RPM range for long trips (switching from 4th to 5th every now and then to vary the rpms).
#23 | |
if that is not a matter, drive it as you like from the very first mile. it's my advice as a mechanical engineer, two things seems to be important: use mineral oil for the first thousands miles and never rev high a cold engine. rage2: what you are saying is all about the oxygen sensor, the hotter it gets the faster it starts work at his normal range |
#24 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I really never gave the car a break-in since they come already tested from the factory. I just droved it hard a couple of times. I just think my engine came with the expected 106hp since we know hp factory numbers are estimated.
I Drive a 129whp Yaris ;) |
#25 |
Down With the Sickness
i drive it like i stole it, hehehe
Strength - Determination - Merciless - Forever |
#26 |
No, I'm not talking about a cold engine vs a warm engine, I'm talking about 2 identical engines, one broken in "easy", and one broken in "hard", or drive it like you stole it. The engine broken in hard will be more powerful.
#27 |
#28 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
Drive it like it's hot... Wow, Chino actually changed his avatar!!!!
#29 |
I worried about the break in period as well. I drove mine as prescribed in the manual, varying speeds for the first 1,000 miles. I changed to Mobil 1 at 2,000 and follow factory intervals of 5,000. Now at nearly 15,000 miles, I've never burned any oil and get great gas mileage.
2007 Silver Streak Mica Yaris S Sedan 5 Speed dojo TSUKAMI Shift Nob Brake Light Pulser Daytime Running Lights http://www.webelectricproducts.com/products.htm |
#30 | |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
#31 | |
The only time I run a easy break-in procedure on a car is when I'm building a new motor from scratch, for about 100km, to ensure the rings and walls are contacting smoothly. After that is an oil flush, then hard break-in!
#32 |
Back in USA in days!
When I test drove a yaris it only had like 30 miles (I went home with it that night) I left the lot and waited till I came to the first stop and then let her loose, I chirped the tired shifting into second and beat the hell out of the car for about 15 minutes. Currently have 11,000 miles on car and no problems.
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID. |
#33 |
![]() Drives: 2007 Meteorite Liftback Manual Join Date: Apr 2007
I broke mine in with a combination of long highway trips and red line WOT shifting in between. Currently have just over 3200 miles and the oil level hasn't ever gone down a drop, which indicates rings are well seated and the break in was a success :) I think people (myself included) stress needlessly about the break in. Just think how many cars are out there that people buy new and aren't even aware of the term "break in" and drive their cars for hundreds of thousands of miles.
#34 |
![]() ![]() Drives: 2007 Yaris Hatch Join Date: Apr 2007
#35 |
![]() ![]() Drives: 07 nissan titan, 07 yaris Join Date: Jun 2007
honestly with such low horespower i didnt even consider going easy on it...plus with a nice warrenty how can you go wrong ? we never keep our vehicles past 30k tops...so none the worry.. i got my titan with 7 miles on it and i go WOT everytime...my tires dont like it but theyve gotta earn their keep lol that also helps out my 10mpg average haha
2007 TITAN SE fram boost intake, or,bt,cc,rf and other cool gismos.. sisters 2007 toyota yaris, bone stock.. [IMG]http://i8
#36 |
Hack.... What hack ??
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
| is the yaris for me? | sauruman | New YARIS Purchase Forum | 14 | 02-27-2006 08:27 PM |
