![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Hi all.
I think many of you know that the speedometer readings in some Yaris are not accurate. I suspected this and confirmed with GPS. I found that a speedo reading of 100kmh had actual speed of 90kmh. I was playing around with Techstream and I ran the instrument cluster diagnostic. I found that the speedometer was infact inaccurate and even the tachometer !. Please see these videos I made. In the second video I test the digital meter which IS accurate. Techstream speedometer test on analog meter: https://www.youtube.com/watch?v=5LLENLt-is4 Techstream speedometer test on digital meter: https://www.youtube.com/watch?v=yFrP4yERDzY I think its quite interesting. ![]() Anyone else tried this out ? Is there anyway to 'calibrate' the speedometer? |
The only way I have found to calibrate them is to digitally modify the signal between the transmission and the cluster. I have only had to calibrate due to tire size differences (and only correctly 2-3 MPH at 60 MPH).
I have never seen one that far off though. I would almost suspect that the stepper motors that drives the needles are damaged from someone removing and re-installing the needle with too much force.
Modded Moderator
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
| Tags |
| speedometer |
| Analog Speedometer instead Digital | Sesjusz | DIY / Maintenance / Service | 7 | 07-01-2014 11:42 AM |
| speedometer probs. | rajjii | Off-topic / Other Cars / Everything else Discussions | 2 | 09-29-2013 10:56 AM |
| Tacho , Speedometer with fix on my car | selimesen007 | DIY / Maintenance / Service | 0 | 07-11-2013 05:20 PM |
| Speedometer Calibration / DeMetrification | CTScott | DIY / Maintenance / Service | 17 | 10-06-2012 09:00 PM |
| DEBATE: Analog vs Digital - Class D vs Old School Amps | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 64 | 06-09-2012 01:34 AM |
