Old 12-25-2014, 01:00 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
If the NGK plugs number ends with the suffix -11 they are pre-set to our gap. Otherwise you should confirm/adjust the gap. If I recall our gap is .43 but double check your manual.
I installed the NGK iridium spark plugs are they pre gap from factory?[/QUOTE]
Old 12-25-2014, 08:05 PM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
[/QUOTE]
Correct me if i am wrong. But is the BKR5EIX-11 for the 1.3 Yaris and BKR5EIX is for the 1.5 ltr Yaris? what is the difference? I think i got the wrong plugs.
Old 12-27-2014, 06:31 AM   #3
junorico24
junorico24's Avatar
I ordered the BKR5EIX-11 so the 11 at end means it's pre gap?
There's also one with no 11 at the end. BKR5EIX, I'm confused lol.
I looked for 1nzfe engine spark plug code it's listed as BKR5EIX with no 11 at the end.
Old 12-31-2014, 08:25 PM   #4
junorico24
junorico24's Avatar
Decided to change the battery it didn't really get rid of the wrrrrrrrrrrr sound and hesitation on start up.
So i changed the coil pack and behold it seems to cure it also the ride is better so far less jerk on take off and better pick up.
Spark plug change to iridium BK didn't do much either except improve the mpg slightly.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Ignition coil Jlively Performance Modifications 4 10-14-2014 08:28 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
