Old 01-02-2015, 11:55 AM   #1
Kar98
Drives: 2011 Scion tC
So because I'm a little bit lazy and didn't feel like crawling around the asphalt parking lot, I asked two places near my apartment how much they would charge to lift up my car, undo two bolts, put in the TRD sway bar, fasten four bolts, and put the lift back down. Sounds to me like 15 minutes at most. Both places said hour, hour and a half. JFC! In an hour, hour and a half, I am sure can do this myself laying in the dirt.
Old 01-17-2015, 04:35 PM   #2
Kar98
I did it in 20 minutes in the parking lot.
Old 01-23-2015, 09:02 PM   #3
jcboy
Drives: Sedan 07
Haha. i've asked around for that too. apparently the cheapest way to do this is to put it in as an "alignment checkup" with results = no alignment needed. here it costs roughly $2.50 for that. pretty cheap for a lifter use. :)
Old 01-23-2015, 09:09 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Alignment check will still cost money most shop's will charge half hr shop rate and believe me will find something wrong to justify alignment lol
It calls for about 30 min to install done the right way problem may be with the lower shock nuts depending on ur region... Heat may have to be applied to remove had to do that to my car cos of winter's here.
Old 01-23-2015, 09:11 PM   #5
jcboy
Drives: Sedan 07
oh...whoever said that going that "alignment" route was a good idea is a fool. LOL i meant we can all do it in our garage. LOL LOL
Old 01-23-2015, 09:12 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Agree with u 100% lol
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Trying to install sway bar Black_griffin6 DIY / Maintenance / Service 16 11-30-2011 03:40 PM
Rally Sway Bar setups Bill@WORKS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-23-2009 09:01 PM
sway bar... Toyota dealers must be insane! RedRide General Yaris / Vitz Discussion 10 07-24-2009 03:39 AM
