Old 01-15-2015, 06:16 PM   #6
Originally Posted by Ryze268 View Post
I'll be running a maximum of 8psi
Is this the correct one:
http://www.ebay.com/itm/Fuel-Pressur...b5f063&vxp=mtr
That is an aftermarket one that is supposed to be compatible. The cheap aftermarket ones look very thing. I am not sure if they would hold up to the modification process (which consists of increasing the spring pressure). I have to adjust, test and repeat a bunch of times until I get it to the correct setting. It is tricky, as there is no going back if an adjustment takes it too far.
