Old 01-21-2015, 08:36 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I changed out my Tail light gaskets and I still have leak inside my spare tire. I gave up. I just pulled the drain plug and leave it open. Water drains out from there now so i no longer worry about hitting the brakes too hard and water rushing to the front of the car.
My car is now in the garage, but I may tackle this mystery after I get it back on the road.
-Derrick-
Old 02-19-2015, 01:47 AM   #2
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
my car leaks from somewhere up high. not the tail lights. i'm still trying to find it but the water stains behind the paneling start well above the tail lights. this could be the case with yours too. i sealed the weather stripping, the strut connections for the hatch, the wiring gromet rubber, the windshild fluid gromet. all that's left is the antenna and the area where the hinges of the hatch are connected to the top of the car. if sealing these last areas works, i'll post back.
El Kapitan is offline   Reply With Quote
Water leak to passenger side AND driver side TMR3 DIY / Maintenance / Service 7 05-21-2017 07:19 AM
DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) CTScott DIY / Maintenance / Service 15 12-30-2015 06:27 PM
Water Leak! Failed Relays cfeng DIY / Maintenance / Service 0 12-13-2010 05:21 AM
Water leak on carpet Rick1234 General Yaris / Vitz Discussion 2 10-31-2010 09:10 PM
07' HB Water Accumulation in hatch bobolinko General Yaris / Vitz Discussion 9 09-26-2010 02:55 AM
