Old 01-24-2015, 01:03 AM   #1
ipwnr
Drives: 2003 toyota echo 1.5l manual
Talking my echo turbo build log
hi guys im starting a new build on my echo. i got a td03 turbo for free from school and that just gave me enough motivation to actually think about boosting the little car. as of now i have the turbo and a small intercooler off of a mazda millenia. currentley what i have done to the car is
echo rs leather steering wheel
echo rs aluminum rims
echo rs seats
removed spare tire
power steering delete
a/c delete
changed clutch (used a toyota celica clutch and pressure plate)$80 off ebay lol
muffler delete
turbo gauge 4in1
aem fi/c
and now a list of things still to do
install aem fi/c
custom turbo manifold
oil lines / coolant lines
intake piping
tires (planning on hankook optimo 4s)
rebuild turbo
i dont expect to get much hp from this tiny turbo (looks like a 0.3 ar)
maybe 150ish but i do plan on getting a bigger turbo in the distant future.
ipwnr is offline   Reply With Quote
Old 01-24-2015, 08:39 AM   #2
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Looks good, keep us posted :)
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 01-24-2015, 10:00 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
looks like the turbo seals are shot. Hope you're doing a rebuild on it first.
Old 01-24-2015, 10:03 PM   #4
ipwnr
is there any way of checking the seals without installing it? because i know the volvo that it was on had a bad pcv.
Old 01-24-2015, 10:42 PM   #5
You can pressure test it off the car. I would test it to at least 80 psi. The easiest way to do so is with air. Plug one of the oil ports and charge the other. I built a rig for pressure testing things that has a quick disconnect air fitting, then a ball valve, then a 3 way T with a pressure gauge on the second leg and the connection to what I want to test on the third. attach it to the device, connect it to the air compressor and charge it to the desired pressure, then close the ball valve and watch the gauge. If it starts to drop, then you have a leak.
Old 01-24-2015, 11:22 PM   #6
ipwnr
thanks for the tip. i hooked it up to a little 12v tire pump and i started hearing a hissing noise at around 5psi:/ so i guess i got to rebuild it. i might try an ebay rebuild kit.
Old 01-25-2015, 12:45 AM   #7
Bluevitz-rs
Was the air coming out of one of the turbines? Also is there any shaft play?
Old 01-25-2015, 01:28 AM   #8
ipwnr
yes the air was coming out of the compressor side and there is a bit of shaft play
Old 01-25-2015, 08:28 AM   #9
Bluevitz-rs
It's definitely something to put on the 'to do' list then.
Old 01-26-2015, 03:59 PM   #10
ipwnr
well after driving around and hearing a clunk on every bump i found out that my rr shock was blown :/ good thing i have a parts car.
Old 01-26-2015, 04:15 PM   #11
Bluevitz-rs
That sucks. Luckily they're really easy to change.
Old 01-26-2015, 04:59 PM   #12
ipwnr
yeah real easy. the last echo i did it on took 5 min and i didn't even need to jack the car up
Old 01-31-2015, 03:55 PM   #13
Ryze268
Ryze268's Avatar
Any updates?
Old 01-31-2015, 11:42 PM   #14
ipwnr
getting the replacement shock from the parts car but otherwise nothing new. this will probably be a slow build since im still in high school and its not my no.1 priority but i will still post updates if i get any new parts.
Old 02-13-2015, 03:40 PM   #15
ipwnr
here is a little update on the turbo.
got the turbine housing off with a hammer and chisel
compressor wheel came off with ease
turbine side bearing has score marks on the outside O.o
could not get this circlip off so i stoped here for now
Old 02-14-2015, 09:11 AM   #16
Bluevitz-rs
Needle nose pliers won't fit?
Sent from my iPod Touch
Old 02-16-2015, 01:26 AM   #17
ipwnr
ok i got the little circlip out and got the the rest of the turbo apart.
Old 02-16-2015, 09:11 AM   #18
Bluevitz-rs
That is one cooked turbo. Hopefully you can clean it all up and rebuild it.
custom, echo, td03, turbo
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 12:26 PM
XB HKS turbo kit, on an echo taKuto Forced Induction Forum 28 01-14-2013 10:39 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
build Log : take 2... FcukThis In Car Entertainment + Electronics (audio / video / alarm) 62 09-15-2010 04:00 AM
